20-Turquoise
Apr 16, 2013 12:09 PM UTC
To_Nested.
Hello Everyone,
The question : Need help to create a function as the following:
Thanks in advance for your hint and help.
Best Regards.
Werner_EAnswer
Apr 16, 2013 3:47 PM UTC
The problem is the symbolic result of "lsolve" in the under-detetrmined case. This result is kind of a list which does not seem to be processable automatically. Whle you can copy it manually and use it as argument in the augment function, it won't work assigning it a variable and use that in augment.
Apr 16, 2013 3:03 PM UTC
The input argument (vectors, separeted by commas) seems not to be a valid Mathcad expression to be manipulated.
23-Emerald I
Apr 16, 2013 3:04 PM UTC
like so?
Werner_E25-Diamond IAnswer
