Topics in Physics.zip
- 0 replies
- 19513 views
- Translate All
Topics in Physics contains examples and worked-problems and solutions in physics. The goal of this collection is to demonstrate how Mathcad can be used to solve problems you may encounter in your classes, physics or otherwise. In using this collection, you will see how Mathcad:
- provides an interactive laboratory for you to explore the concepts behind the problems
- immediately recalculates all results, including graphs, after you change definitions, numbers, and variables anywhere in a document
- can be used for its what-if capabilities by experimenting with the problems and seeing what effect your changes have
- aids you to more fully understand your course material through the visualization tools available in Mathcad
