Trying to set up a combobox displaying two columns
I am trying to get a control looking something like this (from another piece of software) PaulN_0-1669997469713.pngThe nearest I have been able to get is this
And even this is showing an error
I have a feeling that what I want is not possible but it would be great if I could be proved wrong!
ttokoro
ttokoroAnswer
I added all data from excel sheet.
Prime 8 sheet attached.
t.t.
Do not use [ pKa ] - use pKa only.
regards
Owe
PaulN1-VisitorAuthor
That's great but what about getting the dropdown to show the values (in my example 4.74, 2.69 and 5.41) as well as the names - I think that might be a problem which would be a showstopper for me.
DJNewman
Well, you could cheat the combo box and just put the value in the name.
But otherwise the fastest way to check all of the values of the combo box, besides evaluating its contents below it, is to right-click and select edit.
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
ttokoro
You can copy & past this matrix by select all to combo box.
t.t.
Thank you
