trying to understand PDE
I am trying to learn PDE in mathcad,.. Its my first time with PDE, could anyone pls help me with this?
Thanks in advance
Its unclear to me what you are trying to do.
q is treated as the spatial variable name first, but when it comes to the BC you treat it like a functon!?
n(q,t) is neither defined nor searched for.
u is first defined as a function in 1 variable and then used as if its a function in two variables.
Concerning the syntax of the Pdesolve() call Alan pointed you in a previous thread to the appropriate help page. Please read and use the information given there and study the examples and the quicksheet.
math1-VisitorAuthor
this became a bit confusive, when i used u many times.
well this is what i want to define actually du/dt (q,t) = -n (q,t)*v (q,t)
what do u mean by BC?
And what do you know about n and v? You are just searching for u?
Boundary condition.
It looks to me like you have an ode system, not a pde. Look at odesolve.
The attached file contains some comments and questions aimed at pointing you in the right direction (I hope!).
Alan
math1-VisitorAuthor
thanks! I will look on it
