two questions? need help
  • November 5, 2012
  • 7 replies
  • 2909 views
1.First question? How i can change axis unit? i want degree? i was searching tip in google and only find answer "To set the units in a plot, divide the plotted parameter by the desired units" i don't know how i can do it?
2.Second. I need answer of my graph, i need a (alfa) value where the functions are collising?
Best answer by ValeryOchkov
1 use alpha/deg on the x axes
2 use Trace
2 use Trace
thanks
thanks
You welcome!
One Mathcad-video from LT:
http://communities.ptc.com/videos/2101
