23-Emerald V
The picture is very unclear.
You should ALWAYS attach the (or a) worksheet that demonstrates the problem.
The unit should be only MPa but in the result the unit is MPa/Pa . You can find it in page 6 , the sheet is attached
ttokoro
Prime10 shows MPa.
t.t.
