undefined variable issue of reference file
Hi
MathCAD 15, I use references a lot with success but yesterday I met some bug for the first time.
My file became big and I decided to split it into two parts - processing and postprocessing.
I created a new postprocessing file and insert processing file as a reference at the beginning of it.
I post-process (output) variables of processing file and meet several variables which are not defined.
I checked them at the end of processing file - they are defined.
Has anybody had the same problem with references?
23-Emerald V
Can you post the files?
ifomenko1-VisitorAuthor
 Unfortunately, I can`t (: I can try to simplify them (delete some parts that outside of undefined variable) but what it gives me?
yes,I have a few global vars in processing file
-MFra-
 have you fulfilled the following rules?
furthermore there must be no redefinition of functions, variables and constants in each worksheet.
Create daily copies of the main worksheet and possibly of the other files as well.
