-MFra-
Unimath fonts
Hello everyone in the community! I have a small problem: some fonts disappeared after uninstalling PRIME 9 and then installing PRIME 10. In Windows Character Map, the Math unimath fonts have disappeared. How can I recover them without having to do a system restore with the hope that those fonts will be recovered?
23-Emerald V
Why did you uninstall Prime 9?
You can have all versions of Prime installed simultaneously on the same machine, with the exception of Prime 3.0 and 3.1 (installing 3.1 removes 3.0). Note that you can only install them in sequential order.
-MFra-
-MFra-21-Topaz IIAuthor
It was the trial version and it had expired so it was useless. I currently still use MATHCAD15. I'm trying out PRIME 10.
DJNewman
The trial version /  Express version / paid version are all the same installation; they just differ based on what licence is configured.
As for the Unimath fonts... I'm not really sure.
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
Community Moderator
Hi @-MFra-,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
