Unique Function
I need to recall the unique numbers for an array or vector to remove repeat/dupliate values. This can be easily done using the Excel's unique function. Is there a function in Mathcad or a simple program line to accomplish this?
SLS
Something like the attached?
Mike
Try the Stuart's set function. I adopt it in http://communities.ptc.com/servlet/JiveServlet/download/91267-12172/set.mcd
Can see also http://communities.ptc.com/message/91270#91270, between others post.
Regards. Alvaro.
Mike
1.The rotate(n,v) added for its great utility.
2. Drop(V) w/o match applied after rotate(n,v)
jmG
Here's another one, that works for matrices as well as vectrors
SLS1-VisitorAuthor
Thanks to all who replyed. The examples are excellent and my was question answered.
SLS
