Unlock area in MathCAD
Hi ALL,
i have a mathCAD sheet, in which a area is locked by other user and not visible for edit and review. Kindly help me to unlock the same.
for Excel, VB number of unlock swares are available. is thr any software in same kind to so for MathCAD.??
Vasanth.
Please explain where the worksheet came from, and why you think you are entitled to the material in the locked area.
I have a similar problem.  I have several old MCD files from which I would like to recover the source code.  I still have (but don't use) a functional Mathcad Prime 2.0 that makes MCDx files. It does not seem to be backward compatible. I am retired and not in a position to take on a pricy upgrade, particularly for this limited purpose.  .  Anyone have any useful suggestions?  If I had pdf files of the programming, that would serve my need.
If I understand correctly, you have a different problem. You have old .mcd files that Mathcad Prime can't read. If you have a license for Mathcad Prime that license will also work for Mathcad 15, which you can download here: Thank You for Your Interest in PTC Mathcad 15 | PTC
