-MFra-
Unwanted Font mutation
In some of my worksheets, there is a lot of space dedicated to the text. Although I use the "Times New Roman" fonts, it happens that after closing the file and then reopening it, I find the fonts changed to "Arial". Can anything be done to stop the mutation?
Thank you very much!
Franc
I never experienced this effect and so I probably can't be of much help here.
Maybe you should state if you are using real Mathcad or just Prime.
I guess its Mathcad 15.
Do you set the text font to Times globally as default so that it is subsequently used by all text regions you create, or do you set the font separately for each text region?
-MFra-
-MFra-21-Topaz IIAuthor
I use Mathcad 15 (045). I, on the other hand, have always been subject to this effect. I set the fonts for each new worksheet and I don't change them in the whole worksheet.
