Updating guess value in looped solve block
- 3 replies
- 1340 views
- Translate All
Hi all,
I have a solve block function inside a program. The program iterates through an array, finding a solution for each element in the array. The problem is that the initial guess value does not work for all elements in the array. I would like to be able to use the previously calculated solution as the new guess value for the solve block. Is this possible?
I can't post the whole sheet, but I've attached an extract which hopefully shows what I'm trying to do.
