usage of fsin and fcos
How does Mathcad handle sin and cos, appearantly Intels implementaion has its limitations...
https://software.intel.com/en-us/forums/topic/289702
On Line
sin(36001)= 0.01745241
Mathcad
Excel
0,01745240643728350
so not really relevant but better than Excel?
Could be depending on the FU or GPU used, juts in case...
regards
Efried1-VisitorAuthor
The images is not shown it says 0.1745240643728353
On Line
You certainly don't mean 36001 but 36001°, aren't you?
I am not sure what your question is.
Are you moaning about the fact, that there is a difference between sin(36001°) and sin(1°) in the 14th decimal?
Did you run into any problems because of this?
I guess if your calculations really rely on more than a dozen significant decimals, Mathcad may be the wrong tool.
BTW, you can't embed pics via copy and paste, you have to use the "Insert Image" icon to do so.
