Using match function in a loop
Hello folks,
I ran into this problem of the match function. When used in a loop it claims to not have found a match. When used on its own it works just fine; see attached worksheet.
Does anybody know why? I'm using MC15 on a Win 7 machine.
Thanks in advance
Raiko
RaikoAnswer
Tghank you Mike for the hint. It led me to the solution. I simply had to trap the error when match didn't find a solution and now it's working like a charm.
Raiko
Please upload the Excel data.
Raiko17-PeridotAuthor
here we go Mike. It ought to work however with any Excel data.
Raiko
Firstly are calling the wrong column of Q? Should you be calling column <2>?
