Using Matrix with Prime 3.1 API
  • September 6, 2016
  • 4 replies
  • 2943 views
does anyone of you have an example on how to deal with matrices with Prime 3.1 and the API. I want to create a matrix, fill it with data and then send the matrix to Prime.
The SDK does not contain any example for that.
Thanks in advance
Jan
Jan
The READPRN function in not ready for this task?
Perhaps Andrew Carter‌ can help you.
He said:
I have succeeded in sending a matrix of numerical values with and without units, and also individual string values.  But can't seem to find how to send a matrix of strings.
In the following thread: Solved: Trying to populate string data array using API - PTC Community
Here is some code that may help:
var appCreate = new Ptc.MathcadPrime.Automation.ApplicationCreatorClass();
Ptc.MathcadPrime.Automation.ApplicationCreator app;
app = (Ptc.MathcadPrime.Automation.ApplicationCreator)appCreate;
Ptc.MathcadPrime.Automation.IMathcadPrimeWorksheet3 ws;
ws = (Ptc.MathcadPrime.Automation.IMathcadPrimeWorksheet3) app.Open(WorksheetFileName);
int numRows = // whatever;
int numCols = // whatever;
Ptc.MathcadPrime.Automation.IMathcadPrimeMatrix matrixValue = (Ptc.MathcadPrime.Automation.IMathcadPrimeMatrix) ws.CreateMatrix(numRows, numCols);
for (int j = 1; j <= numRows; j++)
  for (int k = 1; k <= numCols; k++)
  double valueArg = // In my case I fetch valueArg from some other system here
  matrixValue.SetMatrixElement(j - 1, i - 1, valueArg);
string aliasArg = // whatever
string unitsArg = // whatever;
ws.SetMatrixValue(aliasArg, matrixValue, unitsArg);
perfect this really helps. I am a little surprised that this cannot be found in the SDK. Do you also have an example for the opposite direction (reading of a matrix)?
Have a nice weekend
Jan
