using while loop with break/continue statement
Dear all,
I have a column of values stored in the variable "i". My intent is, I want to utilize a while loop with a continue/break statement to track a specific range of numbers within the column based on a given input row index. For instance, if I input the row-index value of "4", I would like to extract the range of values from the 4th index of variable "i" until the end.
Please help.
Thank you
Werner_EAnswer
Thats what the stack() function is made for!
new:=stack(i,j)
This is what the submatrix() function is made for - look it up in the help.
Your example:  submatrix(i, 4, last(i), 0, 0)
fahmed-214-AlexandriteAuthor
Thabk you for your reply. I intent to use the while loop with break/continue statement because I want each extracted value to be assigned on a separate variable and show the new variable as a range
You would have to give one or better a couple of examples which show what you are looking for.
Show for each example the input values (vector and limit index) and also the data structure you want as a result.
You shure would have a hard time to assign each value from 5 to 100 (your given example) to a separate variable and you sure can*t use it as a Prime range variable!
