terryhendicottAnswer
Dec 8, 2020 6:54 AM UTC
The first error is confusing vector element addressing with subscripted name tags.
Vector element addressing uses the "[" square bracket. Eg A[1 is the second alement of A vector. A[0 is the first by default. You can change the zero base.
Subscripted name tags for variables use the "." dot symbol. A.1 is a subscripted variable name. A.0 is a different subscripted variable name. You can use subscripted variable names for vectors.
The second mistake is you have used the equality binary operator bold= entered as CTRL = for the definition of functions. You should use the assignment equals entered with the colon button ":"
Cheers
Terry
