Van Roomen's problem
The development of a famous polynomial p(x) of degree 45 has already been discussed here. Now I searched further and found Vieta's approach to the ingenious determination of the zeros. His approach, identical to p(x), is p(x) = 2*sin(45*arcsin(x/2)). Mathcad 14 fully develops this. But I fail to get the usual polynomial structure to be able to compare it with the classical default. What am I doing wrong in attached file? Kind regards at Christmas time, Alfred Flasshaar
LucMeekesAnswer
23-Emerald V
Maybe add a second ' erweitern, x'  to the symbolic....?
LucMeekes23-Emerald VAnswer
23-Emerald V
Many thanks also to Werner. In the meantime I also had a small success according to the attachment.
Greetings, Alfred
You may use the symbolics "coeffs" to see the coefficients
Or you may use something like this to see the polynomial
For some days I experience severe problems when trying to embed pictures here in he forum via copy and paste, but you should see what I am talking about in the attached sheet anyway.
@Jaime_Lee  is it just me or is anything going on concerning the forum software?
You could also use the "series" command to get the desired result:
