Variable definition and tolerance display?
  • November 1, 2011
  • 14 replies
  • 5641 views
Hi Frieds,
I want to define two variables A and B:
A=485.193(h6) mm , where "h6" is the tolerance and "mm" is the units
B=420.000(+0.15/-0.10) mm , where "+0.15/-0.10" is the upper and lower tolerance, and "mm" is the units.
Is there anyone knows how to define variable A and B to make them display as following:
Best regards.
Jeffery
The only way I can think of doing it is like below.
Mike
Another (imperfect!) possibility attached.
Alan
Similarly to Mike's post, please see the attached.
Norm
Nice Norm, I like your +/- mod
Mike
JefferyGu1-VisitorAuthor
Hi Friends,
Thank all of you for your effort in dealing with this problem.
Best reagrds.
Jeffery
Hi Friends,
Best reagrds.
Jeffery
