VBScript: Get the content of a text region ?
Hallo MathCad Collab,
is there a usable solution to get the content (value?) of a text region object in a VBScript worksheet.regions - loop like this:
Const mcTextRegion = 0
For each rg in Worksheet.Regions
If rg.Type = mcTextRegion Then
TextRegionString = rg.???????
End If
Next
Using a Listbox - Component in Mathcad V13 / V14.
Thanks Burkhard
Unfortunately, I don't think there is any way to do what you want. At least, not any easy way. I tihnk the only way to do it would be to read the entire XML of the file and parse it to find the desired text.
That could be done as Richards suggests, but why would you want to?
Can you provide a little more information or maybe a worksheet as there might be alternative routes to go down.
Mike
I want to assign region.tag = region.text to automate the creation of a table of content (TOC).
