vlookup from a table
- November 7, 2011
- 12 replies
- 6836 views
when i look up a value from a table the answer always has parentheses.is there something in Mathcad other than vlookup where i can lookup values but w/p parentheses. please see attached mathcadsheet. The user pick a beam size, then i would like to be able to read its root beams from column 1 and 2. Also i would like to be able to look up other values as well w/o parentheses. Thank you all!
