Oct 2, 2013 12:36 PM UTC
Voltage Drop Calculations
In this section, a method is presented for the calculation of the voltage profile and power losses with application examples for both open and closed lines. This method may be used to improve the performance of a line by investigating the application of shunt capacitors and other schemes for mitigating the adverse effects of voltage drops.
