Want to show the values of the formula in a table.
As shown above I have created an table with formula but I want to show the values rather than just formula. please help.
Thank you in advance.
Werner_EAnswer
Hope this helps:
Prime 9 worksheet attached
Using a table you have created a couple of vectors (in a very inefficient and elaborate way (like in a spreadsheet calc program like Excel)!
You can always evaluate each vector numerically which will show the values.
If you really want create a matrix you can use the augment() function.
If you need further help with this you'll have to attach the Prime sheet.
Please find the MTC (prime7.0)sheet as requested, also can you please give any reference for augment () and how to use it.
the table is on 4th page.
Werner_E25-Diamond IAnswer
Hope this helps:
