Watermark on mathcad document
Is there a way to remove the MathCad  Express watermark from a printed MathCad document?
Not a legal one that would be compatible with the licence conditions you have accepted.
Or a better answer may be "Sure there is a simple way to do - buy the software and the watermark is gone"  😉
I pay annually for a prescription the last many years as well as this year.
Is that not buying the prescription?
Terry Banach
If you payed for a Prime license and the programme still  runs in the free Express mode with limited functionality, then something went wrong.
You should contact PTC support to clarify why your licence file is not recognised as valid by Prime.
23-Emerald I
If you have a paid subscription and the watermark is still there then you need to reconnect to your license file.  Under options in the M pull-down menu (where you find "save as") is the options tab.
