What are the differences between := in regular math block and <- in loop block?
From my (very limited) experience, in the (if, while) loop, Mathcad doesn't allow := but only <-. I was just wondering how are they differ from one another.
Thank you!
They are both assignment operators, but the left arrow is used within a programming structure, while the := is only used outside a programming structure.
Why this is the case, I've no idea!
Alan
Alan
23-Emerald V
yoohooos12-AmethystAuthor
Could you please explain what does each means?
23-Emerald I
As Alan says they're both assignment operators.  The "left arrow."  { <--} only works in program blocks.  Assignments inside program blocks stay inside program blocks--the assignment isn't valid outside the program.  The { :=} assignment is the more common one, out in "free Mathcad."  That assigns the variable/function for the rest of the sheet (below and right of) unless it is overwritten by another assignment statement.
