-MFra-
What to do to avoid fictitious errors in worksheets created with mathcad-prime-3.1?
Hello everyone, I have this problem with mathcad-prime-3.1: I import  data, with the use of READEXCEL, from a file with extension .xlsx. I made some changes in the argument of READEXCEL, then I deleted the changes. Nevertheless, many variables are no longer recognized. See example in the image below. At first, I modify the β1 index, then I delete the change and the error disappears. How to avoid this "strange phenomenon."
Thanks for your kind attention.
With best regards
FM
please open Case at PTC Support and forward your question to them.
MH
-MFra-
-MFra-21-Topaz IIAuthor
Thanks for your advice. But the site requires privileges that I have not.
Bye
FM
In this case you can ask your VAR to open such Case.
MH
