Wrapping long expression/equation
How to wrap long expression to next line in Mathcad Prime?
In Mathcad 15 it is Ctrl+Enter, This is not working in M-C Prime.
MJ-StrEng10-MarbleAuthor
Could not make it work, I tried various way with no result.
Try Ctrl+Shift+Enter
This is not working.
-MFra-
Are you looking for these operators?
Yes, I am looking to use ENTER with these operators
But PTC provides no means to change the keyboard shortcuts for the command. So you can't change them to use the Enter-key but you'll have to use the shortcuts PTC has implemented which are Ctrl Shift and the operator (+, -, * or /)
