6-Contributor
Write CSV file
When using the WriteCSV() function
At what point does mathcad actually write the file?
When you close the program
Periodically?
How do you force it to update the CSV file?
Thanks in advance
23-Emerald V
Mathcad generally writes data to file upon execution of the statement that implements the write function (similar for read).
Once written, there is no need to write again (Mathcad is lazy). If your data is updated and you need it written out again, make sure the statement gets executed. Generally this is accomplished by putting the cursor on the write statement en pressing F9.
rscott6-ContributorAuthor
6-Contributor
I still cant get this to work.
Mathcad will NOT update this file.
I dont get.
No matter what i do or dont do it will not update.
F9 appears to do nothing. I have opened and closed mathcad. I have deleted the CSV and tried to force it to recreate it.
It will not do push the new data. This is a simple Colum vector. Can someone please lend a hand
23-Emerald V
Maybe you should attach the Mathcad sheet...
