Wrong Answer
I attached my MathCAD 9.0.0.0 file.
The correct answer for the 1st part is...
If BB_14100646_1-1758121381432.png, I get the wrong answer...
If I remove the "min" units BB_14100646_3-1758121550032.png, I get the right answer...
...I don't know why it's doing that, but worst case, I can live with that. The 2nd part answer should be...
However, it won't calculate the answer...
There might be a problem with the variable Ct because before there was a box around just that variable in the equation. Now the box is around the entire equation.
23-Emerald V
Unfortunately, you've hit the perennial problem of trying to use units in an equation that has already had the units precalculated to get the desired units (eg, hour to min) and/or removed from the equations.
The power of 0.125 is a strong indicator that the terms inside the parentheses are unitless numbers. Indeed, the symbolic failure flags up a unit incompatibility error (note that rhs divisor adds 1/min to a number).
Removing units gives the following:
Stuart
(I haven't got MP9, so didn't post the amended worksheet)
23-Emerald V
Stuart
That works! Thanks!
23-Emerald V
No worries,
Stuart
