XMCD files
Few years ago I was teached Mathcad (14) at school and made my exercises in Mathcad.
Now a friend needs some help and I don't have the programme anymore. Now I want to open the files again but I can't download Mathcad 14 anymore and I also can't convert the files with the Free Mathcad Trial.
How can I take a look at my files?
If I can convert them to PDF that would be oke, I just need to look to the content of my files.
Thanks!
23-Emerald V
Did you download the Mathcad Prime trial or the Mathcad 15 trial (as mentioned in the quoted post below)?
RJ wrote:
The first thing to do is download and install the latest release of Mathcad 15, and see if that fixes the problem: http://www.ptc.com/product/mathcad/free-trial/thank-you
If the M15 trial didn't work, then you may have a damaged file.    In which case, you could try posting the worksheets and see if anybody else can open them and either create a pdf version for you or attempt to fix the worksheet (it's often due to corrupt Region that can be edited out).
Stuart
23-Emerald V
Sander Palmans wrote:
Thanks Stuart.
The M15 trial doesn't work either so then it's probably a damaged file.
My files are in the attachement. Maybe someone can try if they can be opened?
Thanks!
I think you must have some other problem with your set up.  The first three files opened without any problem (Mathcad 14.0 M035 (14.0.3.374 [908181139])).
I've reposted them together with a pdf (and changed the paper size to A3 to make sure everything stayed within the page right-hand boundaries.
Stuart
