Oct 11, 2021 11:36 AM UTC
XMCD, MCD Converter
I'm using Prime 7 and want to convert some Mathcad 15 documents but for some reason the converter button is greyed out and not clickable.
Any tips how to get it working?
terryhendicott
Oct 12, 2021 4:07 AM UTC
In PTC Prime 7 the converter also comes as a stand alone application.  Go to the start menu, letter P, PTC and you will see a menu item for the converter.
Cheers Terry
terryhendicott
Cheers Terry
Oct 12, 2021 5:36 AM UTC
Thanks for the reply. I can't find any stand alone application. I think I will need to reinstall it then and see if it comes them.
Best regards
Karl
Oct 12, 2021 11:10 AM UTC
XMCD, MCD Converter is a standalone application and always was a standalone application in Mathcad Prime, but it was always installed unconditionally when Mathcad Prime was installed.
In Mathcad Prime 7.0.0.0 the following changes were made.
- Converter does not require Mathcad 15 to be installed on same machine anymore.
- Converter is an optional feature that user can choose to install or not to install.
Looks like you did not install it. Run the PTC Installation Assistant again and be sure to check the XMCD, MCD Converter check box on the Customize Application page.
Emeritus
Oct 14, 2021 12:17 PM UTC
Hi KL_10077042,
It appears from MSheykman on this Post  answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
vnamboodheri
May 24, 2022 6:27 AM UTC
Hi @vnamboodheri The link in your post above just re routes to this post for me. so doesn't show an alternative post with the solution. Unfortunately I cannot find the solution to this same problem as I have installed several times now and on each occasion there is not an option to install with the convertor.
Anyone with some advise ?
May 24, 2022 7:21 AM UTC
My problem was when we installed Mathcad on my PC we just forgot to check a box to install the converter. Either try to reinstall or just run the installation again (think I had to reinstall). It should be a check box somewhere to also install the converter.
