Змінити мову
Добрий день. Допоможіть змінити мову в програмі на українську або на російську. Дякую
Changing language unfortunately is only possible to do via a command line switch.
You may create a desctop icon to start Prime and edit it so the program call is
"C:\Program Files\PTC\Mathcad Prime 11.0.0.0\MathcadPrime.exe" /culture:ru-RU
(The path may differ according to the version of Prime you are using and which path was chosen when Prime was installed)
This does not work for files you open by double clicking on them.
For this to work you would have to fiddle around in the Windows registry.
Or you open Prime first via the modified desktop icon and then double click the file. This would open the file in the already running instance of Prime.
BTW, supported languages are:
Supported languages Command Argument
English en-US
French fr-FR
German de-DE
Italian it-IT
Japanese ja-JP
Korean ko-KO
Russian ru-RU
Spanish es-ES
Simplified Chinese zh-CN
Traditional Chinese zh-TW
