8-Gravel
Can I install Mathcad Prime 7 and Prime 9 on the same machine?
Hello - Please let me know if it is possible to install Mathcad Prime 7 and Prime 9 on the same machine.
Is there any technical limitation / restriction imposed by the PTC installer ?
Regards
Vijay
VladimirNAnswer
I do believe it is possible, you just need to use different loadpoints for each install.
I know when you need MathCAD 15, it must be installed before you install any versions of Prime.
VladimirN24-Ruby IVAnswer
