Feb 3, 2021 11:36 PM UTC
Cannot Install. Can't see selected application
I am still in the stage of installing mathCAD. When I am in the wizard, I am unable to see any applications to select in the 3rd stage. (Application Selection) I can only see where the default installation path is and I am also unable to see where I can browse another path if you have that setting. I hope you understand my problem and able to fix this or send another installation folder that doesn't have this problem. Thank you in advance,
Kind regards,
Billy
VipulTAnswer
Feb 5, 2021 12:03 AM UTC
Hi @WW_9806318,
Verify that you have complete admin privilege's over the system
Also, run pim_installmgr_mathcad_6V2.exe as administrator. https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download/install
Vipul
VipulT16-PearlAnswer
Hi @WW_9806318,
Vipul
