Feb 2, 2021 2:57 PM UTC
cannot install trial version of mathcad
installer does not allow me to select any software to install.
I get to the "application selection" step, and there is no application to select. Install button is grayed out, and I cannot proceed. (i'd attach screenshot, but it doesn't appear that I can attach images)
    Feb 5, 2021 4:49 PM UTC
    Hello @PA_9804110 ,
     Run the installer "Setup.exe" file as "Run as Administrator" - Should help.
    Harry
    Feb 9, 2021 10:33 AM UTC
    First, unzip the install package.
    After clicking next you see a screen the legal text:
    You need to accept the software agreement and also tick the box at the bottom:
    After clicking Next you will see what's about to be installed:
    This can differ depending on what's already installed on your computer. Normally you just click on 'Install' and then you have to wait a few minutes
    After clicking 'Finish' you will hopefully see a Mathcad Prime icon on your desktop:
    Using the 'PTC Mathcad Prime 6.0.0.0' start menu item or double-clicking on the icon will start Prime:
    Feb 19, 2021 9:35 PM UTC
    I go through the steps to install the trial version of Mathcad 15 but in Step 9, I get the error message "A problem was encountered during the MSI installation".  I tried to install by being the administrator and then without being the administrator.  I got the same error message.
    Feb 26, 2021 10:08 PM UTC
    @JM_9824469
    Please Refer article to address the MSI error -
    https://community.ptc.com/t5/PTC-Mathcad-Installation/Error-Mathcad-Configuration-A-problem-was-encountered-during-the/m-p/715719#M283
    Harry
