Configure License Mathcad Prime 9.0.0.0 Trial
I am trying to configure the Trial license version for Mathcad Prime 9, this is the error message I get when I try to configure using the file I received via email:
Failed to configure license for PTC Mathcad Prime 9.0.0.0: Access to the path 'C:\ProgramData\PTC\Mathcad Prime\MathcadPrime.exe.V7.config' is denied.
    I installed the trial on another laptop, and it works.
    Luis Aponte
    18-Opal
    Luis Aponte
    Did you install the program in the default path?
    LA_29581931-VisitorAuthorAnswer
    Luis Aponte
    23-Emerald V
    Chances are that if you simply delete the file
    You are then able to use Prime 9.
    (Prime will create the file when it is absent.)
