Mar 22, 2021 11:04 AM UTC
Error during Installation - Error at 1%
Good morning, guys.
I've struggling to complete the installation of the software of yours.
It always ends up with an error, no matter what.
The error message appears after completing 1% of the installation as follow:
"Some applications failed or cancelled. Click information icon of failed application for details"
Although, when I click it for further details, it just states the obvious ... that the "installion has failed " and it has created a log about the error , this which I could never find.
Looking forward for a feedback for support.
It's kinda frustating.
And I'm in really need of the software right now.
janikoiAnswer
Mar 26, 2021 7:14 PM UTC
Hi.
I was able to install software.  I located installation files which PTC Web installation assistant -software download to computer and then installed manually.
  • First run pim_installmgr_mathcad.exe and when it gives "error at 1%" after downloading files
  • Go  (Windows 10) C:\Users\YourUsername\AppData\Roaming\PTC Download\MED-XXX-XX-XXX_X-X-X-X\ptcsh0\
  • run PrimeWixInstaller_64bit.msi installation file.
Hopefully this help.
Mar 26, 2021 5:01 PM UTC
Hi.
I have same issue.
23-Emerald V
Mar 26, 2021 5:05 PM UTC
Mar 26, 2021 6:02 PM UTC
Hi.  I did follow instructions and 'run as administrator'.
Installation package is pim_installmgr_mathcad.exe which I request from PTC.
I have Prime 5.0 installed on my PC and I though that there could be some issue because of that. So I uninstalled 5.0  but than not solve issue and I installed it back.
Little bit longer errorlog.
Installation failed, refer to the installation log file for more information. You can Restart the failed application installs or click Exit to close the installer. You have Mathcad Prime 6.0.0.0 or earlier version installed, Earlier Mathcad Prime will work as a stand-alone application, but earlier Mathcad Prime integrations with other PTC products will no longer work. See Installation Guide for more information.
I request installation package now from https://support.alfasoft.com/. Let see is it same package or different.
Thanks for support!
janikoi1-VisitorAnswer
Hi.
Apr 8, 2021 12:13 PM UTC
It works. I would only update to go to the folder that you unzipped the Mathcad package.
Apr 6, 2021 8:14 AM UTC
Hi Ramon,
Do you still have the same issue?
Have you tried the solution suggested by janikoi?
Saad
3-Newcomer
Apr 29, 2023 8:34 PM UTC
I have been trying to repair a function with a new istallation, but I keep getting stuck at 0% on downloaded files in the installation  step.  This has persisted for over 24 hours.  I need this program functioning, any help or updates would be much appreciated.
Britt
Apr 29, 2023 10:48 PM UTC
3-Newcomer
Apr 30, 2023 12:23 AM UTC
Yes, been through as much of that as I could including the multistep process to look for the PrimeWixInstaller_64bit.msi installation file
All I have there is the contact file.; no PrimeWixInstaller_64bit.msi installation file
I have spent hours and tried everything I can find to try..
I have spent lots of time on this, because I desperately need this software working to finish up a class.  I had MathCad running, but wound up uninstalling to reinstall it because the worksheet converter was not working and I cannot get the reinstall to work.  This is extremely frustrating and I have spent several hours fighting this because I do not have a choice.  I really need someone to help.
