Jan 8, 2021 12:25 AM UTC
Error "PTC Installation Assistant has stopped working" when running setup.exe for Mathcad Prime".
Error "PTC Installation Assistant has stopped working" when running setup.exe for Mathcad Prime" (Applicable only for SUA Edition)
 Cause:
  1. Microsoft for .Net Framework is missing or is not installed correctly
  2. Microsoft Visual C++ 2008 SP1 is not installed correctly
Resolution:
  • Run PrimeWixinstaller_64bit.msi from the ptcsh0 folder of installer 9.3.jpg
  • Run the fix provided by Microsoft for .Net Framework 4.5.1
  • Try to uninstall and re-install Microsoft Visual C++ 2008 SP1 Redistributable Package:
    1. 32 bit
    2. 64 bit
