Find searches collapsed areas but does not re-collapse if nothing found.
I am using Mathcad Prime Release 9.0 and Datecode9.0.0.0
When searching for text or math in a document using the Find box and Find Next button in the status bar, collapsed areas are expanded but do not re-collapse if nothing is found. For documents with many collapsed areas this is difficult to manually re-collapse each one.
1) Is there a simple way to collapse all expanded areas in a mathcad document?
2) Can the find algorithm be updated to re-collapse any collapsed areas where nothing is found?
My current workaround is to lock all collapsed areas, but this is not ideal either.
Note: Mathcad Prime 8.0 did not have this issue, since find did not search any collapsed areas.
    MichaelWAnswer
    Please note that PTC Technical Support created an article to collect experiences and expectations about Mathcad Prime's worksheet range search (Find) feature:
    CS401416 Search/Find in worksheet functionality is less comfortable in Mathcad Prime
    Where issue was reported to R&D on 18-SEP-2023 as SPR 14861215 with severity High
    You can Subscribe to above article and related SPR notifications to get updated on the resolution status.
    (click on the ... symbol on the left edge of the article)
    23-Emerald V
    Every improvement is (involves) a change, but not every change is an improvement.
    In this case, Prime 9 was changed with respect to Prime 8, most probably due to this idea: https://community.ptc.com/t5/Mathcad-Ideas/Collapsed-Area-Finds/idi-p/760767 .
    A couple of things went wrong:
    1. The change is not advertised in the "Whats_new.pdf" file for Prime 9.
    2. The search functionality was changed to a bad implementation.
    I guess someone changed the program but only got half way.
    Seems like PTC.
    MichaelW17-PeridotAnswer
