Highlight Region in Prime Version 6
How can I highlight a region? This was very easy in Mathcad 15 where you just right click and select highlight, but now I can't see how to do it in Prime and I've searched through all the forums and there is nothing about highlighting a region in there. I just want to highlight input so the user of the worksheet clearly know what regions are to be modified.
    Hi @CH_9440646,
    Text regions(text box, text-block) can be highlighted using "Highlight Color" option under Text Font group from Text Formatting tab.
    To highlight the Math region/input it can be highlighted by navigating to Math Formatting tab and then selecting the region and using "Highlight color"
    I hope this helps
    Vipul
    Thank you Vipul! Easy enough.
