I have some old files, not able to open those
we have mathcad 1988 version 2.0 which no longer support, these files are generated from same version in the year of 2007-08
so now, i am not able to open those files with new version of mathcad
any suggestions?
Did you try Input/Output > MCD Converter? Works for me...
Yes, did not work
terryhendicott
Can you upload one of the files so it can examined?
Cheers
Terry
Here is the sample file
terryhendicott
The file extension is *.mcd indicating earlier Mathcad not Prime.
In Prime on the ribbon at the top go to input/output tab.
Third icon from the left is XMDC,MCD Converter. Select this icon and a dialog box opens.  You can add *,mcd files, and then convert them.  It places the new converted files in the same directory with same name and an *.mcdx extension so Prime can read them.
I have done this with the enclosed file.  Works Ok with some setting out problems.
You need to go to Prime ribbon "Document" tab, to the "draft" view to see all the calculations to the right of the page width.
Cheers
Terry
