Feb 26, 2026 12:39 AM UTC
IF OTHERWISE RETURN VS IF ELSE RETURN
I used the MCD converter to convert an old worksheet. The converter changed a conditional statement from IF-OTHERWISE-RETURN to IF-ELSE-RETURN. It stated the results are still accurate, but that is not entirely the case. I don't know how to change it back to the original conditional statement. Is there a way to change it?
23-Emerald V
Feb 26, 2026 5:41 PM UTC
Sure , there is a way to change it. But. regarding such branching:
• Mathcad supports only IF and OTHERWISE
• Prime supports IF, ELSE, ELSEIF and ALSOIF.
(In all cases a 'THEN'  is implied between the condition and the statement at the end of the line.)
Note that I do not consider RETURN as part of an IF... branch. RETURN provides its argument (whatever follows it) as an unconditional result of the function. It can be used as an expression in an IF construct, but also in a WHILE or FOR construct, and (preferably) at the (normal) end of the function.
I would assume that ELSE is a correct replacement of OTHERWISE, but it may depend on the structure of your program. Can you post the file(s) or at least the snippets, both from Mathcad and Prime?
Community Moderator
Mar 9, 2026 4:00 PM UTC
Hi @EC_14511170,
Anurag
