Installation error mathcad prime 7. 0 - no logs
I can't to install mathcad. The installer always ask to see file log, but there is not a file log showing a problem. Can someone help me?
23-Emerald V
Check here, to see if there's a solution to your problem.
Thank you for answer. But I already checked this link before. The problem is that the installation assistant don't show what is failing, it only show a message saying to see the installation log file. So I don't even what is the error in installation. Is there any way to solve it?
23-Emerald V
Did you find that LOG file. I suspect it should be somewhere in:
C:\ProgramData\PTC\...
Note that the C:\ProgramData folder may not be shown on your system by default, but you should be able to navigate there by typing the path in Windows Explorer.
