Jan 17, 2022 12:30 PM UTC
Installation of mathcad 7.0
I have a problem with installation of mathcad version 7.0. I have installer, recieved it via e-mail. When I try to install it, after runnig installer, there is only extraction of some files, the window disappears and nothing is happening. I tried to download full version of installer from website https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp but there is no file under the name of Mathcad 7.0. I had the same issue with 6.0 version but on that time there was a full version of installer on that site and it helped.
Kind regards
VladimirNAnswer
Jan 19, 2022 8:29 AM UTC
Jan 17, 2022 8:16 PM UTC
Jan 18, 2022 7:03 AM UTC
Thank you for response but it is not working. After runnig the installer and extraction of files, there is no such folder like PTC Download in folder Roaming. C:\Users\YourUsername\AppData\Roaming\PTC Download\MED-XXX-XX-XXX_X-X-X-X\ptcsh0\
It seems as if the installer does not create this path at all.
Jan 18, 2022 7:20 AM UTC
What Windows OS are you using?
Jan 19, 2022 7:26 AM UTC
@DP_9497767 wrote:
...  I tried to download full version of installer from website https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp ...
Additional link:
https://support.ptc.com/support/mathcad_downloads.htm
https://support.ptc.com/appserver/lm/mathcad/download/index.jsp
Jan 19, 2022 7:30 AM UTC
In the first link you have to give all the data including email, company etc. I did it and i recieved only this installer that is not working for me.
Unfortunately i had only mathcad 6.0 express so i don't have any product code to give.
VladimirN24-Ruby IVAnswer
