7-Bedrock
lmadmin_ptc service running but ptc_d fails to start: Not a valid license server system host
I am using Mathcad Prime Release 9.0 and Datecode9.0.0.0
Clients are unable to open Mathcad, error -61 Cannot read license file data from license server system.
Deemon log shows:
No such feature or vendor does not exist: ptc_d
13:37:53 (ptc_d) SLOG: FNPLS-INTERNAL-CKPT1
13:37:53 (ptc_d) SLOG: VM Status: 4
13:37:53 (ptc_d) SLOG: FNPLS-INTERNAL-CKPT5
13:37:53 (ptc_d) SLOG: TPM Status: 0
13:37:53 (ptc_d) SLOG: FNPLS-INTERNAL-CKPT6
13:37:58 (ptc_d) THSVRSYNC: Not a valid license server system host. Exiting.
13:37:58 (ptc_d) daemon shutdown requested - shutting down
13:37:58 (ptc_d) SLOG: Summary LOG statistics is enabled.
13:37:58 (ptc_d) SLOG: FNPLS-INTERNAL-CKPT1
13:37:58 (ptc_d) SLOG: VM Status: 4
13:37:58 (ptc_d) SLOG: FNPLS-INTERNAL-CKPT5
13:37:58 (ptc_d) SLOG: TPM Status: 0
13:37:58 (ptc_d) SLOG: FNPLS-INTERNAL-CKPT6
13:38:04 (ptc_d) THSVRSYNC: Not a valid license server system host. Exiting.
I've tried restarting the lmadmin_ptc service and tried replacing the license.dat (the old license.dat expiration date showed 22-dec-2024). Also tried importing a license file.
DT
Here are the errors that I faced
-96: Cannot connect to license server
    7-Bedrock
    I modified the SERVER name in C:\Program Files\PTC\FLEXnet Admin License Server\licenses\ptc_d and it works now.
    Thanks a lot.
    David
    Check the hosts in the old and new license file.
    Possible solutions - "Error (-96)": https://www.ptc.com/en/support/creo-admin-troubleshooter/error-code/error-96
    GI_108701927-BedrockAuthorAnswer
    7-Bedrock
    Thanks a lot.
    David
    You're welcome.
