9-Granite
mathcad prime 10 can't calculate
I converted a program that was working in mathcad 15 with the mathcad prime 10 converter and started the calculation, but it froze midway and the screen became white and unresponsive.
Please let me know if there is a cause or solution.
Translated the topic from Japanese to English using google translate
Subject - mathcad prime 10 計算ができない
Body - mathcad 15 で動いていたプログラムを、mathcad prime 10 のコンバーターで変換し計算を開始したのですが途中でフリーズし、応答なしと白い画面になります。
原因や対策などあれば教えてほしいです。
- By Community Moderation Team
LucMeekesAnswer
23-Emerald V
The cause is the fact that Prime 10 doesn't know all the tricks that Mathcad 15 can do, or uses a different implementation of the tricks.
The solution will follow from an inspection of the sheet(s).
I think that apart from the Prime 10 sheet as Terry suggested, it could be beneficial to see the Mathcad 15 sheet as well.
terryhendicott
Upload your worksheet Mathcad Prime 10,  It is probably just taking a long time to process.
Cheers
Terry
こんにちは、
ワークシート Mathcad Prime 10 をアップロードします。おそらく、処理に時間がかかっているだけです。
乾杯
テリー
LucMeekes23-Emerald VAnswer
23-Emerald V
