3-Newcomer
Mathcad Prime 12 solver blocked by Windows 11 Smart App Control
I have recently installed the 30-day evaluation version of PTC Mathcad Prime 12.0.1.0. Mathcad installs and opens normally, but I have encountered a problem when using a solve block.
A very simple test with an initial guess x := 1, the constraint x³ = 8, and find(x) fails.
Mathcad reports that it cannot load efisolver because an Application Control policy has blocked the file. The error code is 0x800711C7.
Windows Event Viewer also records Code Integrity Event ID 3033 when Mathcad attempts to load:
C:\Program Files\PTC\Mathcad Prime 12.0.1.0\knitro1510.dll
My computer is running:
- Windows 11 Pro
- Version 26H2
- OS Build 26300.10075
- Windows Smart App Control: On
The Mathcad evaluation installation was downloaded directly from PTC and I have not modified the installation files.
I have seen PTC guidance suggesting that Smart App Control may need to be disabled. However, I am reluctant to disable a Windows security feature simply to make the Mathcad solver operate, particularly since Mathcad itself installs and runs and the problem occurs when the solver DLL is subsequently loaded.
I would therefore appreciate advice from PTC or other Mathcad users:
1. Is this a known issue with Mathcad Prime 12.0.1.0?
2. Have other users encountered Smart App Control blocking efisolver or knitro1510.dll?
3. Is an updated or correctly signed version of these components available?
4. Is there a supported solution that does not require disabling Smart App Control?
I have screenshots showing the Mathcad error, the Code Integrity Event Viewer entry and the Windows Smart App Control setting, which I can attach.
Thank you for any assistance.
