Mathcad Prime only on certain wifi
I received a license to use while the estore was down from a representative, but it only worked when connected to the wifi I set it up with. Now I purchased the mathcad student prime version, but still, it only works with whatever wifi I am connected to when I set it up and get only express version everywhere else. Is there a way to fix this? I paid for the license and need to be able to use it in different settings.
23-Emerald V
The license file is (should be) tied to the MAC address of the internet connecting device of your PC, normally that is either the MAC address of your Wi-Fi adapter inside your PC, or of the LAN card inside your PC.
You may be able to move the license to a MAC address of your PC with this info: https://community.ptc.com/t5/PTC-Mathcad-Installation/Transferring-Mathcad-Single-User-or-Student-license-from-an/m-p/788338#M1600
Otherwise you'd have to contact that rep.
Community Moderator
Hi @CB_12404424,
Anurag
