"Microsoft VBScript runtime error Line:15 Error:0 Object required:"ComboBox"
I am using Mathcad Release 15.0 and DatecodeM050
FDOT program within Mathcad 15.0
We tried the resolution from your knowledge based
https://www.ptc.com/en/support/article/CS281384?source=search
- user is using Mathcad 15.0 with updated date code M050
- installed MS Office 32 bit.
The issue reoccurs with the same error.
Here are the errors that I faced
Microsoft VBScript runtime error Line: 15 Error:0
Object required: Combo box
    What version of Microsoft Office x32 did you end up installing?
