"plot y-values in reverse order" ?
I am using Mathcad Prime 7.0 7.0.0.0
Simple Question: in the attached how do I make the plot with the y-axis with the minimum value at the top of the plot and the max value lower?
In MS Excel this is called "plot y-values in reverse order"
    terryhendicott
    Nothing is attached?
    There is no reverse order that I know of. Simply set yplot:=0-y then plot x vs yplot..
    Or export to excel to plot.
    Cheers
    Terry
    you may wish to use the "reverse" function that "inverses" the order of elements in a vector or array. See the attached Mathcad 15 sheet.
    HI @MR_9302175,
    Please share the sample worksheet for further troubleshooting the issue
    Vipul
    I've already attached it to my previous post. This is what it looks like
